info required !
Just moved in to a new house
i currently have what seems to be a spur from the house running to the garage.
i removed the socket that was in place and added 3 ie (total 3).
the cable running out to the garage seems to be 2.5mm (not what i would of used!)
I would like to add Garage Consumer Unit as the consumer unit in the house is fused.
is this a good idea?
what max rating would you suggest ie 16A/5A MCBs
also can the garage then became its own ring?
i guess i'm still limited by this 2.5mm cable that links the buildings?
at some point a new consumer unit will go in the house, but not until the kitchen is re done. 6months away
