Hello,
I have a computer connected to a UPS in my closet
The computer is turned off properly on power failure (via the UPS software). However the only way to power it up after power restoration is to press the power on button.
Please note that the computer is turned off before the UPS battery gets empty. So UPS power may or may not fail (that rules out the use of BIOS settings to power up computer).
I would like to know if there is a device (relay?) that I can connect to the mains (directly, not the UPS) and signal the power on. The device should short circuit the motherboard's power switch pins momentarily when AC is restored, simulating the push-to-make switch.
Is there such a solution? If you can suggest alternatives please do.
Cheers
Cheers
