The people fitting new bedroom units in 2 weeks have told me to arrange a power cable to the top of the wall to use as power for the bedroom units lighting. I cannot come from the loft as it is floor boarded.
Advised it was an easy job - open up a socket, add a fused switch spur with a 5amp fuse, and then chase a cable from the spur to the ceiling.
On further checking, it did not seem a problem as long as the socket was in a ring main and not already a spur from a ring main. I was advised to check each socket I want to use to ensure there was cable in and out.
However I have checked ALL the upstairs sockets and each only has cable in, I assume from this they are not in a ring.
Can I still add a fused spur to a socket or do I need to call in an electrician for further checks?
