powering 3 outdoor lights from 1 timer?
23 Jun 2006
I've just sent a spur from my ring main into an FCU mounted on my living room wall, which then goes through the wall and into a weatherproof socket on the outside of the house.
I've only wired the cable into a weatherproof socket for the moment as I want a brick flowerbed built with 3-4 brick lights built into the wall.
Once this has been built i'll remove the weatherproof socket and extend the cable into a weatherproof box that is attached to the side of the flowerbed. Now, my question is how do I connect 3-4 brick lights each with their own seperate plug to a timer in the weatherbox so they all come on at the same time?
Basically I only have the 1 wire coming out of the external wall - is this enough to do what I need?
wire them all in paralele, or their transformers in papalell. but the socket should be supplied by an rcd
