    Dismiss Notice
PR5208 rev1.1 and Risco GTEW002G2B
Discussion in 'Alarms, CCTV & Telephones' started by Listy600, 25 Aug 2019.
  1. Listy600
    Listy600
    25 Aug 2019
    2
    Thanks Received:
    Country:
    Hi, my daughter has just moved into a house that had the fuse pulled to the control unit. When I reapplied power I got a constant bleeping and "low bat" on the display. I've replaced the battery and the panel has "unset" and a date of 1 Jan (the chime works on the front door sensor).
    Unfortunately, the previous occupier hasn't left any user or master codes - I've tried 1234x and 5678x but just remains "unset".
    Is there a way to default to factory settings?
    Any help/advice appreciated.
  2. Sponsored Links
  3. Handymanjo
    Handymanjo
    2 Feb 2016
    1,522
    Thanks Received:
    284
    Newark
    Country:
    Look at eurosec cp8l
    If you do not have user code then panel will need to be defaulted.
    Control panel code be engineer locked
    • Thanks Thanks x 1
  4. Listy600
    Listy600
    25 Aug 2019
    2
    Thanks Received:
    Country:
    Thanks. I've defaulted the system, which has reset codes (incl. Engineer), but now has "tamper" on display. Will investigate further when I get chance.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
