prefab home help!
13 May 2013
Leeds
I've posted this in decorating as well, but thought I'd post it here too.
My house is a nightmare! Moved in about a year ago, and now finally getting round to decorating.
It is a prefab (post war I think) property. The previous occupiers put up nasty embossed wall paper, covered with beige gloss finish paint in every room. I have no idea what is behind the wallpaper, but on a hunch I think it might just be plasterboard, as you can see the joins quite easily. I've taken a bit of the wallpaper off in one room, but have no idea what I am looking for. The wall is bright orange underneath, what is this? All my previous homes have been plastered, and am a bit of a DIY novice, so not entirely sure where to start!
Ideally I don't want to plaster anything, can you paint straight onto plasterboard? Or does that increase the risk of damp?
Help!
21 Nov 2008
uk
It will just be emulsion under the paper.
Painting directly onto plasterboard is quite normal and causes no issues.
I doubt your walls will be good enough to paint onto without a lot of sanding /filling and even then will still look naff.
13 May 2013
Leeds
Have pulled off a fair amount already, and so far they dont look to bad, no cracks or anything. What should I do so it doesn't look naff?
21 Nov 2008
uk
Wait till you have it all stripped then you can decide if you can sand and paint it, line and paint it or bite the bullet and get it skimmed.
19 Jan 2008
Be careful as if I remember rightly we had a lot of prefabs in Birmingham and I think that some of the construction consisted of Asbestos.So before you do anything else just get it checked or enquire around .I hope I am wrong ,But you must make sure. ;)
6 Dec 2005
Devon
hi is it a house like this?
http://www.***************.co.uk/wp-content/uploads/postwar-housing-whitleigh-plymouth.jpg
If so the fella is right, it may contain asbestos. They used it before they knew it was harmful. Just to be sure, i would be wary of sanding down the walls, maybe get a builder in to take a look?
