Preferred method of finding a level?
  • Thread starter Thread starter hollywood
  • Start date Start date
H
hollywood
What's the best preferred method for Your level.
Fixing a baton?
Or say working off a long spirit level that's fixed to the wall?
Just got one of these, makes setting out easy.
Very useful devices for setting out differential building & equipment levels when used with a staff (a laser Theodolite is light years ahead of anything Screwfix sell) but wont help much with tiling. They are very good at projecting levels & will give you a very straight & level (visual) line; good enough for many things but will rely on your (very) good eyesight to fix a base line batten to the wall to support that all important first tile row!
A good spirit level used to fix a perfectly straight batten will be far better. For battens, I use extruded aluminium section of varying lengths; if the batten is not perfectly straight, the tile rows will get more “out” the further up the wall you go.
Just transferred the laser line to wall with a pencil in a few places and joined up the dots, checked with a level and spot on.Have used ali flat section for baton before.
Water level, far more exact for setting height marks over distance and also from 1 room to another :wink:
ah ha the good ole roman method,yep cant go wrong with 1 of these.
done a few shop fronts with them,but i havnt picked up a water level for yonks.
you take 1 end, i will take the other and we can set a perfectly level line from me to you :wink:
