I have wired in alarms before but I have not done EOL I think I understand it but can someone tell me if what I am doing is correct
I have PIR with jumpers which can be set for EOL resistance, which I have set. So do I now but one wire into the alarm circuit (if so which terminal) do I then place 1 wire into the tamper circuit (if so which terminal) and I intend to double pole the remaining 4 wires 2 for positive 2 for negative on the power supply.
Do I then place the Alarm wire and tamper wire into the respective zone on the control panel, and obviously the power cables into the power supply on the control panel
most zones will have just 1 PIR, 2 zones will have 2 PIR, and one zone will have 3 PIR do I wire the multi zones in series? and would the resistance be the same?
Safe Dave
Safe Dave
