First of all many, many thanks to all the knowledgeable people on here who give up their time to help the adventurous DIY'ers who take on installing a "proper" alarm system.
I have spent the last few weeks browsing these fora and have learned a huge amount. After much research and looking at the pros/cons/quality and capabilities of different systems, I'm now the proud owner of a self installed Texecom Premier Elite 48 with a Ricochet Expander, GSM Comm and COM-IP. All hard wired apart from two door contacts with a plan to add Panic Switches and Smoke/Fire detectors soon. Programming the panel has been a voyage of discovery and I'm pretty much where I want to be (TXT and Push working well).....but I'm stumped on one thing. I'm not sure it's possible (having spoken with Texecom support) but I'm wondering if there's a work round/custom output which could achieve my aim. Here goes.
I have an "evening" part set which monitors two very rarely used entrance doors to the house and also the garage door and shed door. In this part-set I have omitted the front door and the patio door because I still want to be able to use them. All doors are hardwired DP/EOL 2k2/4k7 contacts. When the system is unset the front and patio doors chime (desired) - when the system is "evening" part armed the doors in question do not chime (not desired!) I assume this is because they are omitted - and Texecom Support indeed said that the system does not monitor them because of this. However, using Wintex diagnostics, when the system is part armed the zones show "Auto Omitted" as expected.....but when the doors are opened the Zone Status goes "Active" from "Secure".....so the system does see/monitor the state of the zone.......but it doesn't chime. Very frustrating!
I've looked at custom outputs (???????!!!!!!!!!) - not exactly intuitive (!).....so my plea is to the gurus and masters on here......can it be done?
Many thanks
A4
PS My panel was delivered with Rev 2.11 firmware....just before the update was released(!) Is it worth flashing the panel to Rev 3.00? The extra ARC's may be handy but not sure I'll gain anything else - other than being up to date.
4
Many thanks
A4
4
