    Dismiss Notice
Prep for painting hardwood floor (previously varnished).
Discussion in 'Floors, Stairs and Lofts' started by rarara, 11 Sep 2017.
  1. rarara
    22 Sep 2010
    191
    Thanks Received:
    Glasgow
    Country:
    Am looking to paint a maple floor in a lounge (please don't suggest leaving it natural :whistle:) that has previously been sanded/varnished, with what I believe was a solvent-base polyurethane.
    What sort of floor paint is recommened - water, oil based etc?
    Is a primer needed?
    What sort of prep - keying sufficient?
    Thanks!
  2. chappers
    27 Aug 2004
    3,186
    Thanks Received:
    339
    Country:
    a decent clean and sand, both water and oil based are available I would definitely prime according to the recommendations of the manufacturers of the paint you choose.
    I know you said don't suggest leaving it natural, but can I ask why not.
  3. rarara
    22 Sep 2010
    191
    Thanks Received:
    Glasgow
    Country:
    it just doesn't look good within the room itself, when alongside our furniture, fire surround etc - its quite dated looking
  4. chappers
    27 Aug 2004
    3,186
    Thanks Received:
    339
    Country:
    fair enough, to be honest if you want it back it should be possible to sand the paint back off
  5. Doggit
    27 Jul 2013
    5,146
    Thanks Received:
    739
    Kent
    Country:
    I'd go for an oil based undercoat and top coat for wear strength. You'll need to prime it first with an acrylic primer, then 2 coats of undercoat, and then at least 2 coats of topcoat. That would be fairly standard for most woods, but being a floor, you don't want the paint to wear too quickly. But have you thought about a stain instead. Maples fairly light, so should take a stain easily, and then it's up to you whether you varnish it again to get a good wear surface, or just leave it stained and natural.
  6. rarara
    22 Sep 2010
    191
    Thanks Received:
    Glasgow
    Country:
    can i ask why an acrylic primer if the stuff going on top is oil based?
    also, is the primer and undercoat you suggest a specific floor version? (previously primed and painted pine, but can't remember what primer i used :rolleyes:)
  7. Doggit
    27 Jul 2013
    5,146
    Thanks Received:
    739
    Kent
    Country:
    Most primers are okay, so maybe I shouldn't have said acrylic, just used to it; and I don't think it raises the grain as much as water based one do, so only needs a lighter sanding afterwards.
Share This Page
