I am in the process of re-fitting an en-suite bathroom and have just removed the old tiles from the bathroom. I intend to do the jobs I can myself but will get a professional in to do the tiling - however I want to know a little more information before I get quotes.
The old tiles were on plasterboard walls, over which there was a thin layer of plaster skim. Removing the tiles from the wall has left tile adhesive stuck to the wall in some places, the plaster skim in others, and in some the skim has come away to leave just the plasterboard.
Obviously the walls will need to be fixed up before tiles are attached, but I'm unsure what the best option is:
1. Remove everything down to the plasterboard and tile directly onto the board.
2. Remove everything down to the plasterboard, re-skim and tile onto the plaster.
3. Remove as much as possible, skim over whats left and tile onto this.
My guess is that option 3 will be more prone to tiles coming off later as the plaster is unlikely to be as well attached to the wall. Other than that, I'm not sure what the best option is - 1, 2 or something else (I really don't want to be taking out and re-fitting plasterboard walls).
If I am to remove the old adhesive and skim, what's the best way of getting it off? It seems to flake off reasonably easy in some parts but is better attached in others.
Many apologies if this question has been asked before - I've searched and not found anything, but I am a bit of a novice at this. I just want to have a bit of an idea before I start getting tradesmen out.
