I know absolutely nothing about boilers/plumbing so any help (simplified) is greatly appreciated. I thought I'd try you guys before spending a month's wages employing a plumber
Firstly, the answers to the required questions:
1) Boiler make / model (gas or oil)
Gas Ferroli Optima
2) What is / is not happening.
Overnight, when the heating is off the pressure drops to 0 bar, hence no heating in the morning.
3) Has ANYTHING else been done or changed recently.
No.
4) When did the problem start?
This happened a couple of times a loooong time ago but months apart, however it now occurs on almost a daily basis and has done for about 2 weeks.
5) When does it happen? eg, heating coming on or going off.
The boiler is used for water and heating. The problem happens overnight when the heating is timed to be off (off at 11pm, on at 5am).
6) Anything else you feel may be of relevance.
The heating will not automatically come on at 5am until I turn a switch that re-pressurizes the boiler. This affects both heat and water.
If anyone has come across this problem before or if anyone can make any suggestions as to what it could be I'd be most grateful.
Kind regards.
Gas Ferroli Optima
No.
Kind regards.
