Guys,
I have a house that I let out. The tenants in the house have said that they are having problems with the hot water. Every time they turn on a hot tap it runs cold water for a small while then a bolt of steam fires through the taps violently. This then calms down and hot water then runs until the tap is turned off.
The water is heated by a Mersey instantaneous hot water heater. I have had an engineer around who said that it would be cheaper to get a new boiler fitted then repair it. He didn't seem to be able to confirm what they problem was. Can you confirm whether or not this is the case?
