Hello: I hope that it isn't out of order to post about a pressure cooker! The thing is, many readers use these contraptions, so someone may be able to help me with a problem that has stumped me.
Our Prestige (stainless steel) pressure cooker is many years old. I don't know what model number it is, either. Anyway, last week, my wife complained that it was not getting any pressure (only she does the cooking, not me). She had already replaced the gasket with an unused (bought new) one that had been in the drawer for years, and now, she thought, was the time to change it. However, it still would not get pressure up. Since, on the lid, there is only 3 things (an indicator that shows that pressure has been gained; the little funnel, on which the weight is placed, and a "Ready=to-Serve Indicator"), it could only be one of these three things that was at fault. The weight cannot be it, because after all, it is only a weight. There seems not to be the slightest reason to suspect the pressure indicator (which is a kind of metal stud — about three eights of an inch in diameter — in a plastic surround in the middle of the lld). That would make suspicion fall on the "Ready-to-Serve Indicator", which is a rubber plug, about five eighths of an inch in diameter, set into the lid near to the edge, and which has a metal peg in it. Shortly after the weight has been put on the pressure cooker (with gas-ring full on). this metal peg is supposed to pop up, and seal the only vent through which steam can escape. This then allows the cooker to build up pressure and cook the food.
When I prised out the rubber plug of the "Ready-to-Serve Indicator", the rubber started to break up, being brittle. Ah, I thought, this is the culprit! Yet, after a new one has been fitted (bought fresh from a store on the Web), the pressure still does not increase, and it is therefore impossible to cook in this pressure cooker. The metal peg in the R-to-S Indicator does not pop up automatically, as it should, but even when I pull it up manually (to help it, as it were), the cooker still does not gain pressure.
I am completely at a loss as to how to get this appliance to gain pressure! Can anyone make any useful comment?
With thanks in hopeful anticipation,
L.L.
L.L.
