depends where you live and who you ring,
call a local ready mix plant and find out.
There is bound to be a few in your area, so ring round for best quote.
Some will deliver what ever you order and dump the lot with you, even if you have estimated over, but some will also just do the pour until the area is full and charge you for that amount.
So worth asking about.
Remember cubic measurements are width x depth x length not length x width.
So you have 6 x 7 m as the square area, this must then be multiplied by the depth of your base to give the cubic area.
You will require about 4.5 cube if you lay it 100mm thick.
There are 4 cube and 6 cube wagons available so it may pay you to have say the four and mix a tonne up yourself, as you are penalised for part loads. This you will need to weigh up with the suppliers.
I've just payed £85.00 a cubic meter for ready mix, the lorry mixes what you need and comes with 2 x wheel barrows for you and a mate to barrow in.
No waste this way and they can mix the right grade for your slab.
If you are south london/surrey i can pass on their number i was impressed with there time keeping etc on the 2 occasions weve used them so far.
we have 3,6 and 7 metre trucks this way.like nose says beware of part load charge and also be aware you will get a set time to empty the truck and if you run over they will charge you for this.
