Ok hopefully someone can help dig me out of a hole,...
Nicked a rad pipe while fitting some flooring today, and after swimming for a while managed to drain the system down.
Soldered new pipes in but when refilling system the boiler dosent fire up
The pump sounds on, and someone mentioned on another thread about checking impeller?
Can I run the pump with water drained, as I can remove the bleed screw to check but can't do this with water running
I have bleed all radiators but doesn't seem like there's much pressure
I have a prima f40 boiler
Thanks hopefully someone's can help
