prima lpr600 wash pump
12 Oct 2009
Hampshire
hi, I have a leak in the small hose attached to the wash pump, this appears to be bonded to the plastic, does anyone know if this hose is available separately? a google search shows an equiv pump with the hose attached by a sprung clip, but cannot find this hose on its own, dont fancy having to change the whole pump.
its a bit of a pain to replace the hose but carefull cutting off of the old U/S hose you cab fit a different hose using a jubilee clip to attack it securely.
Thanks guys,
did indeed replace hose with a piece of auto radiator hose and jube clips, no leaks, zero cost, result.
Must try that next time.
