primary / secondary heat exchanger?
24 Sep 2013
Yorkshire
Could anyone out there please explain the purpose of the primary and secondary heat exchanger on a combi boiler.
I dont understand why two would be needed.
Apologies for my ignorance.
Mine is an ariston eurocombi a23 mffi
Jon
The heated (tap) water must never come into direct contact with the CH water. This is achieved by a secondary (plate ) heat exchanger or a second set of pipes incorporated in the main heat exchanger, sometimes called a dual pass among other names.
Even an ordinary system with a cylinder has a coil inside to prevent cross contamination.
