Primed MDF Skirting Boards
19 Mar 2013
West Midlands
I'm wanting to buy primed MDF skirting boards but so far every company I've asked only primes the visible sides. Does anyone know of a supplier that will also prime the backs/underside?
I'm surprised this isn't done given that MDF should really be sealed, particularly if being used in areas such as kitchens and bathrooms.
Don't think the primer gives much of a seal. I'd say none tbh. Can't let rain or water get near it. It's just a naff acrylic primer and very chalky.
I denib it (fine sand) and prime myself with something better.
Just buy some mdf skirting and prime yourself prior to fitting.
MDF skirting board should normally be made using MR-MDF, so priming wouldn't achieve that much. AFAIK the primer is applied to speed up the process of painting on builds
and very chalky.
which is a very good reason not to pick lengths up in your car that has dark trim. Don't ask me how I know,,,,,
Thanks all for your replies. I'll just pick up some decent MR-MDF skirtings. I will still get the face primed though to speed up painting as JobandKnock mentioned.
Don't use mdf in bathrooms.
Use wood and treat it so to last a lifetime.
Unless you want to replace it every few years.
