Looking at adhesives I was opting for bal Single part Flexible with bal apd primer. Now tempted at getting Ardex X7 tech spec looks same as Bal but cheaper , so question is would the Ardex P51 be the equiv of the bal apd? To put down on sand/cement screed
I spoke with Ardex tech guy to see if either could be used, he said if going down on a sand/cement screed don't prime just hoover well to remove dust, but no primer needed? Is that a good idea? Looks like the Bal is acrylic the ardex is water based.
