Problem laying engineered floor boards...
I
imamartian
I'm about to lay a floor at the weekend, and i'm assuming the boards will be those that slot in to the previous board at 45deg and then press flat to the floor to lock.
My problem is that on three sides of the room there are heating pipes which are low and will impede the boards laying flat.
It's obviously fine when i start, but how do i lay the last boards? and what about the pipes along the side wall ?
14 Nov 2004
Kent
THE reason we stick to T&G - too often there are too low radiator-pipes running around the room to get the angle of a click-system working. You'll have to cut off part of the system to get those pieces in, making it the "weakest link" in your floor.
Stick to T&G is my advice
14 Nov 2004
Kent
although it is one of the better videos I've seen on installing a floating floor, I can't see how this has answered your question in regards of the last rows with click-systems and low pipes?
I
imamartian
my understanding now is that the boards can be installed horizontally, and tapped together (mind you, that's not how it went today :evil: ), and with the last board, it's cut to size, slotted under the pipes, and a pull-bar used...
Am i missing something?
18 Jan 2010
Hull
Yes you are missing something..
There are different "click systems" One type that can be fitted horizontally is "uniclic" who make "quick-step" .It's a patented product so no one else can use the same system.
Most, if not all others have their own click system and they all have to be fitted at 45 degrees, so you are going to struggle.
At the very edge of the tongue side of a board the timber is thicker, you can chisel this off, leaving the tongue in tact and glue it in place horizontally using a pull bar.
Also the last board will be 10 or 15mm narrower than the space it is going to fit into as you need to leave an expansion gap.
14 Nov 2004
Kent
agree with Mac
The video shows you how to install the first three rows of a T&G floor, not a click-system.
