Problem removing tap cover to change ceramic cartridge
26 Oct 2008
Yorkshire
I have a dripping kitchen mixer tap and I need to replace the ceramic cartridge.... I have done this before on a different tap....
My problem is that I can not get to the cartridge on this tap.... I understand that I should be able to remove the tap cold cover by turning anticlockwise or pulling - but it wont budge...!
The tap is no longer in manufacture and Magnet do not even know who made it... Here is a picture.
Please help
Is there another allen key grub screw accessible through one of the 'knob' holes?
That would be my guess too.
If not, it'll just be a case of pulling or twisting a bit harder than you've already tried.
It looks to me that the three grub screws are what secures the er cover to the spindle which will be splined. I think it should pull off, perhaps with a little judicious levering. Good luck.
Thanks for the replies.....I think brute force is required, will give it a go.
I think it should pull off too. :roll:
Yea, try sliding a small screwdriver in the gap and try levering it off at the same time as pulling and wiggling with your other hand.
Hope that makes sense. :shock: :?
Thanks again....boiling hot water and a bit of wiggling with a screwdriver did the trick..
Cheers :lol:
