Hi, Can anyone give advice on my boiler problem please.
It's a Baxi Solo which has just stopped working after about 10yrs service.
The "Boiler On" light lights, but that's about it, all the supplies are there and the pump runs. I've gone through the fault finding flow chart which is on the inside of the cover and all seems ok. It suggests to test the sensor, pilot solenoid and potentiometer all are ok.
The PCB is showing signs of heat around a few of the resistors, do you think it likely that it needs a new control board and if so are they readily available/where from?
Thanks for any help Richard
