I have a light fitting with four 35W GU10 halogen bulbs, together with a dimmer switch. The bulbs used to go quite quickly and I understand this may be due to the combination of a dimmable switch and halogen lights, therefore, I have tended to have the dimmer on full or just under.
The other night I turned the dimmer down a little from maximum and the dimmer switch seemed to light up and will no longer work (I live in an area where the power off goes off or reduces during high winds which were present at the time). Having taken the front off the dimmer switch there is a slight black smoke mark. Is this due to a dimmer switch not being suitable for the light fitting or could it be something else?
