HI! I have a shower which has been working fine for years on a 6mm cable from a 32amp fuse no probs until now, it keeps tripping on the mcb so I changed the wiring to 10ml and replaced the msb (another 32amp} and put in a new 2pole switch for good measure but it still trips?? I've ordered a 40amp mcb which should solve the problem but still have one in another room just the same as this one ( 32amp 6mm cable) working fine. so what do you think the problem is????p.s I've checked the earth connections no probs there, the cable run is 4mtrs.
any advice will be gratefully received
