Did you refill by allowing full flow through the ballcock?, it might work better if you just tied it up to let it trickle in although unlike refilling a combined cold feed and vent, I've never seen it suggested to refill your system type slowly, better off as well not to put any inhibitor in until the system is proven to be circulating properly, a rad can then be drained down by a few litres to put the inhibitor in.OK... panic over!! I had to back fill again which didnt seem to do much by way of forcing air out, but after a while and a few gurgles the pump started working properly and all good. Knowing that the wattage being used relates directly to the work its doing - ie very low watts means it's not pumping much - is incredibly useful esp with the USP4 which reads wattage directly on the display. Anyway thanks again for all the help... and I wont be draining the system again anytime soon!
