Not sure it should be under 'DIY disasters' as it concerns a professional installation and it fortunately did not end in a disaster. However, it may be of interest...
We've just discovered the cause of the 'damp' smell in our dining room. The gas pipe under the floor was joined with an unsoldered coupling, and for the last 20 years has relied solely on flux to seal it!
Was this oversight a one off by the original installer? Probably not as the an adjacent CH pipe joint subsequently started weeping. This time the joint had been soldered but a slight movement of it needed for the gas repair man to fix the gas pipe was enough to break the solder joint!
The top pipe in the photo is the gas pipe and the bottom pipe is the CH pipe.
This installation is over 20 years old. Do I feel lucky to still be here!!
Mike
A competent amateur is safer than an incompetent professional! [/img]
Mike
