programer blown
4 Feb 2014
Merseyside
Hi i changed fuse in my daughters central heating and there was a flash and a bang from the programmer can I change it or is there something else wrong with the boiler, and there is no name on the programmer
So the fuse blows and you just replace it without bothering to find out why it blew? :shock:
So why were you suddenly changing a fuse?
Its not a normal maintenance activity!
I suspect it had blown and instead of investigating why, you just replaced it. Possibly even with one at a higher rating!
Tony
Rivermead, the fuse that blew would most likely be a 3 amp fuse (due to some kind of defect) for protection of boiler, wiring and controls. If replaced fuse is say a 5 amp, you would most likely have protection still. A 10 amp or 13 amp even, means a goodbye to the programmer. Hope my explanation is one human being to another instead of headmaster talking to an errant child :roll:
Hi I replaced it with the same fuse 3amp and when a fuse blows do you get some out to look at for £40 or do you replace the fuse your self
It seems that you replaced the fuse and blew a £45 programmer.
You should have had an engineer do it for you!
Tony
