Hi I would appreciate your suggestions or help on this.
I have a Texecom Premier Elite, which I would like to program for 3 scenarios...
I'm thinking of keeping the house sensors in Area A, and the seperate garage in Area B (it has its own keypad).
The keypad in the garage will be allocated to area B only.
Scenario 1
Have a seperate keyfob for the garage, that can only set and unlock the garage.
The garage sensor would need to be allocated to both Area A and B and should be set to guard access. When someone wants to access the garage, the countdown timer starts and they have to either enter the garage code or present the keyfob.
Scenario 2
When away from the house I would like to set the whole alarm. Sensor 1 is door entry, sensor 2 is guard access. The garage sensor should go to guard and essentially be instant alarm. The code for the whole house should be able to set the alarm as above. When the code is used to deactivate the alarm, the garage should go back to being armed with guard access.
Scenario 3
At bedtime, the alarm will be set as a part alarm. The upstairs sensors will be omitted. Sensor 1 should go to instant alarm, sensor 2 should remain as guard access, and the garage should also be instant alarm. The deactivation should be the same as scenario 2.
Is using areas the sensible way to achieve what I want to and how would I achieve the above?
I have a usb cable and access to wintex.
I'd be grateful for your suggestions.
Scenario 1
Scenario 2
Scenario 3
