Pros and cons of water leak detectors
Discussion in 'Plumbing and Central Heating' started by Bratman91, 10 Jul 2014.
  1. Bratman91
    Bratman91
    18 Nov 2007
    42
    Thanks Received:
    Gloucestershire
    Country:
    I would like to fit a device that, when the house is unoccupied, would detect any water leaks and turn off the water. My feeling is that nothing would detect a very slight leak but I would like something more serious to be detected. I would welcome any views as to how effective such devices are and any recommendations as to how, if at all, to go about choosing one.
  2. Bosswhite
    Bosswhite
    15 Jun 2012
    2,911
    Thanks Received:
    405
    Southampton
    Country:
    What do you mean by unoccupied, if its long term, turning off the mains would be the answer.
    Having a water meter fitted and checking it will tell if you have a leak on the consumers side.
  3. Sponsored Links
  4. mogget
    mogget
    18 May 2008
    1,898
    Thanks Received:
    163
    Wiltshire
    Country:
    I can't see how a 'water leak detector' would distinguish between a leak, and normal use. Otherwise you'd be best turning the stopcock off.
  5. Bratman91
    Bratman91
    18 Nov 2007
    42
    Thanks Received:
    Gloucestershire
    Country:
    I recall seeing a device at a home improvements show about 4 years ago but cannot remember the details. I think that it was said to work by being triggered if there was a steady but slight flow over, say, 15 minutes, the presumption being that most normal uses would either be for less time or for fluctuating demands (eg. watering the garden). I think that it was possible to, as it were, set the sensitivity for particular circumstances and it also had provision for manually turning off the water (using as a mains tap). Of course, such a device wouldn't stop every single drop of water leaking out but it would prevent catastrophic damage and would be easier for anyone to turn off the mains than a tap typically placed somewhere dark, not easily accessible and close to knuckle-scraping projections.
  6. Sponsored Links
  7. Bosswhite
    Bosswhite
    15 Jun 2012
    2,911
    Thanks Received:
    405
    Southampton
    Country:
    To make it worthwhile and practical I would have thought it would have to be situated near the internal stop cock and before any domestic outlets . i.e taps to cut off water supply, . or does one fit these to every water outlet in a property ?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
