Protecting Electrical Cables
9 Aug 2006
Kent
Hi all
I have just built a conservatory with the help from a friend in the trade.
I wanted to extent the existing downstairs ring main to add 4 double sockets in the conservatory. I have had a look on the screwfix.com website for protective channelling but they are all plastic. Is this sufficient? It doesn't seem much of a protective layer. A plasterer will cover all cables once the work is complete.
Any suggestions or comments would be gratefully received.
Best regards
Mark.
Thanks for your reply.
As I understand it then I guess I need it as the cables will be run against / along the wall and then covered over with plaster less than 50mm thick and will run outside the zones. I will need to at least cover the cables with an earthed metallic covering/conduit.
I can't seem to find anything other than PVC cover products though.
Maybe it's safer and easier to use armoured cable which complies with BS 5467. My only concern is it maybe a little too ridged to handle.
Does the above make sense and correct ?
Hmmm, reading the links posted I am now all confused.....
.... if I am running a cable vertically down a chased out wall from the ceiling to a light switch and then plastering over with 5-10mm plaster, what sort of protection do I need?
I have re-read http://www.niceic.org.uk/downloads/C5-43.pdf and think I understand it all now.
If you have cables within 50mm of a surface and **outside** a horizontal or vertical zone then you basically need to armour the cable. If you stick within the zones you should be ok. Maybe someone could confirm that.
To clarify a point, if I run cables down from a socket along the base of the wall and then up to the next socket is this still within the zones or would I need armoured cable for that ??
markknell said:
If you have cables within 50mm of a surface and **outside** a horizontal or vertical zone then you basically need to protect* the cable. If you stick within the zones you should be ok. Maybe someone could confirm that.
Confirmed
No. Look at the diagram again. There is no safe zone along the bottom of a wall. Go under the floor if you can.
