Hi All
I rent out a property (flat) - and was informed today there been attempted metal theft of the external gas pipe from the meter leading to the inside of the property!
It has been fixed by a gas safe guy today.
I have seen the damage and it looks like a clean cut and I cannot see how this happened, surely not a hacksaw - it is quite close to the external wall. Is it possible at all for this pipe to just snap over time and came apart when someone tried to handle it?? I've never seen copper snap! The pipework is currently covered in black but surprisedly this did not stop them!
Anyway - about protecting it - what is the best way? The meter is in a box outside..the pipework starts coming down about 200mm then to the right about 200mm and then upwards probably 1500mm and then left about 1200mm and then upwards inside the property. The area is communal so anyone can walk by.
I know there some suggestions of boxing in but also see some info about ventilation needed. If anyone can point me to some kits like Screwfix etc that be great. It could be some sort of clamps etc. I would then go there again and fit it in to make it more difficult for them to try again.
