Hi - we have had our bungalow replumbed - mains pressure tank, all new pipes, radiators etc and the plumber has fitted a PRV pump as a safety feature to pump water out through the loft to outside if pressure gets too high I assume? This is going off intermittently, approx 12 times a day, no water in any of the black plastic indicator traps and no water is being pumped through the release pipework to the outside. It seems to coincide with the water circulating pump starting up, and the boiler is always running when it happens. but doesn't occur every time, and of course not when the plumber/electrican is here. Plumber says it's an electrical issue, electrician says it's plumbing. Any ideas?
