    Dismiss Notice
Pull cord light switch replacement
Discussion in 'Electrics UK' started by Local System User, 18 Sep 2020.
  1. Local System User
    Local System User
    18 Sep 2020
    4
    Thanks Received:
    Country:
    I need to replace pull cord light switch in my bathroom. So I ordered so called 1-way switch without checking what I have first. It looks like I have currently mounted 2-way switch.
    1. This is what I have now:
    https://ibb.co/B3fkZcj
    The current is flowing only on two brown sockets on the right side (they are bridged).
    2. This is what I bought:
    https://ibb.co/mS3WCVF
    How should I connect the new one (if possible)?
  2. Sponsored Links
  3. AndyPRK
    AndyPRK
    4 Jan 2009
    5,190
    Thanks Received:
    488
    Herefordshire
    Country:
    You have a 2 pole one I think.
    I guess you have a fan.
    Do you have a fused plate near the fan?
    Search for 16A pull cords
    • Thanks Thanks x 1
  4. Local System User
    Local System User
    18 Sep 2020
    4
    Thanks Received:
    Country:
  5. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,535
    Thanks Received:
    1,980
    Oxfordshire
    Country:
    Double pole is different to two way.
    Cant see from your photo, what are the markings on each terminal of the existing switch?
  6. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,535
    Thanks Received:
    1,980
    Oxfordshire
    Country:
    • Thanks Thanks x 1
  7. Sponsored Links
  8. plugwash
    plugwash
    28 Mar 2004
    9,166
    Thanks Received:
    310
    Country:
    No, 2 pole means there are two sets of contacts that switch on and off together. 2 way means a contact that switches between two contacts.
    2 pole pull cords are sometimes used in light+fan setups as they allow one fan to be linked to multiple seperately switched lights (for example if two bathrooms share a fan).
    As others have said, the switch in your picture looks like a 2 pole switch. From the wiring I would guess it is indeed being used for a setup where multiple lightswitches are associated with one fan.
    • Thanks Thanks x 1
  9. Local System User
    Local System User
    18 Sep 2020
    4
    Thanks Received:
    Country:
    You can't see it because there are no markings. I hope there will be a short manual attached to the new switch.
  10. Local System User
    Local System User
    18 Sep 2020
    4
    Thanks Received:
    Country:
    Thank you all for advise.
  11. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,535
    Thanks Received:
    1,980
    Oxfordshire
    Country:
    No problem. It’s a simple swop. Mark the wires before you take them off.
    That short link wire needs replacing, there’s bare copper showing.
  12. JohnW2
    JohnW2
    28 Jan 2011
    44,290
    Thanks Received:
    2,806
    Buckinghamshire
    Country:
    If you cleaned it up a bit, there might be some markings to see. It certainly appears to have "LOAD" written adjacent to one pair of terminals (red arrow), and it looks as if there is something (could be an "L" or an "N") adjacent to at least one of those terminals (blue arrow) ...
    Kind Regards, John
Loading...
Share This Page
