park said:
Having removed all the power, checked the PCB for poor joints, found one, what do I do.
That was a question,I was asking what should I do, could I re-solder it or would I need to buy a new PCB.
Perhaps you should follow the usual convention of putting a question mark at the end of the sentence containing the question so that anyone reading it knows its a question!
May be you are correct there, but I would have thought that the statement " what should I do" was as good as a question mark ?
Your clever adjustment of the flow rate inside the boiler has no more effect than you would have obtained by turning a hot tap down lower.
I would refer you to page 19 of the Puma manual,(commissioning) item 3.6 D.H.W. flow rate. to quote " the flow rate can be further reduced by using the manual flow restrictor.
When a boiler engineer says the hot water performance is "OK" that means he has measured both the flow rate and temperature rise. A 24 kW boiler like yours gives about 9.3 litres per minute raised by 35°C.
9.8 litres/min which gives a nominal temperature rise of 35*C
