The heating system in my new house has the pump istalled on the return to the boiler, the feed is on the return by the cylinder and the vent on the flow by the cylinder, the vent is only 15mm .is this correct?
why ask. is there concern of pumping over.the arrangment you have is very common.its only these days newbies are taught vent feed pump arrangement.but with boilers back in the days the heat ex had more water content and resistance as apposed to newer boilers with lower content heat ex.
I plan to replace the old boiler with a new condensing type, i just like to know where i stand before get plumbers in to quote and baffle me with jargon. Had a problem with over venting in an old house which started me thinking.
u have a gravity system and this pipe arrangement is completely ok,when u change boiler it will need changing,and the 15mm vent is incorrect,it should be 22mm
i understand were your coming from, and a very sensible question as a lower water content boiler could cause problems.its hard to say though without looking at the system layout.
