Saw a newly re-located open vented cylinder today with a couple of things I thought odd.
Firstly the feed vent set up was 'H' shaped. The flow came up and became the vent, the feed came down and became the flow. The link (flow) was 150mm and the pump on the exit leg of the 'H'. Isn't this a recipe for sucking air?
Secondly, the coil was fed in 22mm but reduced to 15mm on the return. Any ideas why that would be done?
