Hi all,
I had turned my CH pump down from setting 3 to setting 2 a while ago in an attempt to make life a bit quieter. It did the trick.
However, when it is set to setting 3 it rotates in the correct direction, when on either 2 or 1 it rotates in the wrong direction.
The heating is back on setting 3 and the house is warming up nicely now but the pump is sucking in air on this high setting (it is also fitted pumping down).
I am sure this is an obvious fault, am I right?
I just need to know that not all my marbles have been lost.
fyi. The pump is a grundfos multihead G. It is not a sealed system.
