System:
Ideal Classic FF 250 with Sealed System kit, Honeywell C21 programmer and 2 inline valves (CH + HW).
Have just moved and found that heating did not work - diagnosed and needing a new pump so have replaced.
Everything is now working but the pump does not switch off even when the CH & HW is set to off on the programmer.
Any ideas? Do I need a new programmer? Suspect that the old pump may have had the same problem which may have knackered it in the first place.
As the Honeywell C21 has been discontinued, I understand that the honywell ST6400C can be used without rewiring i.e. same backplate. Am I correct?
