Is my pump pumping the water in the correct direction. According to the installation guide the pump should be on the return pipe to the boiler. However the return pipe gets very hot and the flow pipe is only luke warm. I removed the cover for the electrical connections and noticed a capacitor inside. If this component fails can this cause the pump to turn the wrong way?
