Pump or soak-away?
22 Mar 2006
Cardiff
Quick question- we're having a new boiler and our waste water drainage is quite a long way from where the boiler will be- we've had two differents solutions to dealing with the waste water from the condensing boiler, the first is to pump it into the guttering above, the second to feed it down a pipe externally where it can 'soak way'
Do any of you have any ideas what would be the best way to deal with this waste water from the boiler??
Thanks!
Better to be able to run condense waste internally if possible to protect against frost.
Seems your better option would be to run externally to a soak away, use large bore pipe and have soak away away from foundations.
Properly installed soakaway any time over a pump to chuck it in the gutter.
Any halfdecent installer should be able to sort it out for you anyway.
