I am soon to reconfigure my CH. Currently, my Potterton Kingfisher CF boiler has an open vent and separate feed from header tank, a pump on the flow to the cylinder via a 2 port valve, and another pump on the return from the rads. There are 2 further 2 port zone valves for upstairs and downstairs.
I am considering ditching the header and fitting expansion cylinder, safety valve, filling loop etc, due to air problems. I will also be putting CH pump on the flow side. Potterton manual recommends I connect pump to boiler directly to facilitate pump overun on fully pumped systems (at the moment pumps are activated directly by stats (relays used on 2 CH zones). But when the call for heat or HW stops (when stats are satisfied,) the only route for pump to circulate water will be via an auto bypas valve that will be fitted directly after pump, so my question is: Is there any point in having the pump overrun enabled if all it's going to do is pump water around a couple of metres of pipe in and out of boiler (as all the 2 port valves would be closed in that state)?
Secondly, would it make sense to just have one pump on flow for both CH and HW, seeing that there is a 2 port valve around every bend? ( would need to do this anyway if pump overrun used, unless I make some sort of crude relay logic circuit...)
