Push button cistern - water running into bowl
26 Jan 2008
Belfast
I had a dodgy ball valve and so replaced the whole mechanism. Since then I have noticed a small trickle of water running into the bowl from the cistern.
It's not an overflow issue as the trickle starts as the cistern is filling up i.e. even when the cistern is half empty. Any ideas? Is this constant trickle normal or is there a problem with the flush mechanism?
You may have disturbed or broken something. Make sure that there is a good seal between the bottom of the syphon and the cistern, as water could seep between the two.
As you say its not the overflow, then this is the only other possibility
Do you remember the bad old days when we used to have problems?
These days we only suffer from 'issues'.
Suppose Gordon Brown must be telling the truth when he says things are getting better!!!!
On most of these cisterns the flush assembly is detachable by giving it a twist anti clock wise & lifting up, then you can examine the thin rubber washer to check for damage/debris :wink:
Does anyone know where I can buy one of these? I don't know what make or model it is. I've been to 4 or 5 different plumbing suppliers... no joy! Please help!
I've just found a label on the toilet... it was made by LECICO. Does anyone know who supplies Lecico spare parts :?:
