Great website - read (and learnt) loads - thanks.
I am planning to replace an existing bath this weekend. The connections are similar but not identical to the existing which are run in what looks like 15mm copper. I have seen speedfit tap connectors which look a lot simpler than attempting my first compression fitting. Therefore questions are:
Should I use the speedfit connector between 15mm copper and the replacement mixer taps?
Would I just need PTFE tape to connect the other end to the taps or would an olive still be required?
Thanks in advance for any help.
Jez
Jez
