I have to alter a pipe to utility room sink hot supply that comes up from under the concrete floor of a 1950s extension. The old pipe measures 21.45mm so I assume to be old 3/4"? I need to connect in a very tight hole I've made in the concrete floor and know it will be really hard to stop the water flow from dribbling even when drained down so a solder fitting is not an option.
Hard to get spanners in for a compression fitting so I found online Hepworths do a plastic pushfit for this job. Seems to claim a 50yr design life.
Anyone used these or anything similar?
