Putting a downstairs toilet under stairs.
28 Sep 2010
Manchester
My wife is going into the childminding business and we thought it may be better to put a loo and hand basin downstairs so we only have to make sure the downstairs is ofsted approved.
The under stairs cupboard currently has our washing machine installed so there is a water supply already in situ along with the main stopcock. the cupboard is also directly below the upstairs bathroom with the stink pipe accessed directly through the wall.
The stink pipe is cast iron. I am quite handy at plumbing and have done many successful projects how straight forward is this job going to be? Ive never installed a wc before!
I should also mention that the cupboard is across the hall from the kitchen and is more than big enough for accommodating a low level wc.
Thanks for reading!
cutting in a branch on a cast soil pipe is not for the faint hearted
the rest is straight foreward enough
might be worth getting a decent oldish plumber in to do the stack :idea:
Thanks Kevplumb, you can now see from my other post why I am moving our washing machine! :lol:
As a DIYer, I cut a cast iron stack with my 9" disk cutter and fitted a "timesaver" fitting, which meant I didnt need to dislodge the stack.
From there, it is a case of having the right adaptors in the branch for your loo.
Mind you, my pipe was on a flat wall, outside, with good access for my disk cutter. Check the stack is stable before starting as you don't want the free upper portion to fall before you have the timesaver clamped up.
Website for timesaver
http://www.saint-gobain-pam.co.uk/soildrain/index.cfm?page= Timesaver BS 416-183
Do not, under any circumstances, be tempted to use a S*n*f*o.
Ensure the system has ample rodding points. If you've ever had an action man get stuck round your u-bend you'll understand.
http://www.saint-gobain-pam.co.uk/soildrain/index.cfm?page= Timesaver BS 416-183[/QUOTE]
I have good access to do this, I'll give it a go!
Hi again, just read somewhere that this is notifiable. Is this the case and why?
There is already a water supply in the cupboard, is this just a money making thing or are there legitimate reasons for these fees?
Sorry, having a rant! :x
Hi, can someone confirm that this is a notifiable job, cheers?!?
you get caught
then you get taken to the town square have your britches removed and get a public spanking offa a viking with a soggy kipper :lol:
not a lot as long as its not silly :wink:
well worse they will tell u can`t use it
and i would use hack saw as if some thing goes wromg with power tool u may be up sheep creak with out paddle
Does cast iron cut with a hacksaw easily and how straightforward is it to get a straight enough cut for the fittings?
I found my 9" disc cut the pipe very cleanly and square. I find the electric 9" disc cutter much more controllable than the petrol 12" saws which can get a bit out of hand especially when used horizontally. No doubt practice would improve my skill with the petrol saw.
