- Joined
- 12 Dec 2016
- Messages
- 448
- Reaction score
- 3
- Country
Is it easy and are there any dangers? Is guess drill in then make as accurate as u can cut with a jigsaw?
In the blank panel you mean? Easy - but don't make the hole too small as its difficult to enlarge by a few mm if you have to.
Just cut it the right size, drill a hole and use a jigsaw. Just be wary that the blade can sometimes bend a bit meaning the opposite side to the one you're on can be a bit off if you're not careful. I'm sure someone with even limited diy skills could tackle it. £180 is nuts.
I stuck the template to the door, drilled a hole then cut with a pad saw. It cuts very easily.
The pvc won't crack and split?
Will a jigsaw do it?
