PVC BESA box
16 Feb 2014
Gwent
Hi
When installing PVC conduit, does a female adaptor have to be installed when terminating into a BESA box?
No the entries are sized to grip the outside of a conduit, they are not threaded.
You should however use some solvent weld glue to ensure it does not come apart
But am I right in thinking that female adaptor shave to be used when connecting conduit to sockets? Thanks for your help
If male adapters are used, what needs to be placed inside to allow the adapter to hold the socket to the conduit?
They come with a lock ring to secure the adaptor into the socket (or what ever)
Adapters are supplied with the fitting required inside, in the case of a female adapter this is a plastic bush, with a male adapter its a plastic locknut
Either is fine, but I prefer female adaptors as they take up less room in your socket box.
