PVC door adjustment
9 Sep 2005
Door is sticking at the bottom and need to adjust it. The hinge has two Allen key screws at top and bottom and a small grub screw in the middle. Which screw does what?
The small middle screw only holds the hinge pin in place to stop it riding up when you open and close the door, the other two allen key screws move the pin sideways, moving the top pin to the left and bottom one to the right will cock the door over which could be just enough lift but theres a height adjustment screw under each hinge, thats your best bet
