PVC Wall Panels
16 Mar 2009
Hampshire
Just been putting 10mm panels up and am going to use these type of trims on the corners of the wall around the patio door. That's up both sides and across the top.
https://www.diy.com/departments/aqu...8vg3hB3u6ptUWeeWmtyXMo0yRAY8-j_saAuBAEALw_wcB
I have to cut a 45 degree angle at the top of each so that it joins nicely. My problem is...... old age and the brain not working correctly. Probably a simple thing to do but just confusing and doubting myself!
Can anyone please give me an idiots guide on making these cuts and the best method. I have a mitre block, do I need to place the trim on a piece of wood to get the correct cut??
Many thanks for any help you can give.
